Failed Smog... Help me out
Old Dec 18, 2006 | 01:59 AM
95LSv's Avatar
95LSv
Banded
Not black. But there is a relatively high amount of greyish smoke coming out, when in neutral and I rev it and when idling... I really hope this isn't something really bad. However I did change out my ecu today for a OEM virgin ecu, and I noticed the car ran better and the emissions seemed to lessen a bit. Should I go do a "practice smog"?
Old Dec 18, 2006 | 08:55 AM
Snoopy's Avatar
Snoopy
been there done that
find a no pass no pay station
Old Dec 18, 2006 | 10:45 AM
95LSv's Avatar
95LSv
Banded
Yea, those are hard to find. There are none in my area. Are there any you could recommend??
Old Dec 18, 2006 | 11:12 AM
Snoopy's Avatar
Snoopy
there are a few in my area, but i dont know how far you're willing to travel
Old Dec 20, 2006 | 11:00 PM
95LSv's Avatar
95LSv
Banded
Default Failed Smog Again
So I went back today, after switching out my ecu and putting a stock one and it failed again. Not as bad this time. And it actually passed at 25mph but failed 15mph. Most of the results are really close to the limit however. This time the NO was too high at 15 mph. The guy said that the reason now is my cat. Is that all there could be?
NO (PPM)
15 mph
Max: 708
Meas: 812
Thats the only thing that was over the limit... Plz help me out. Thanx
Old Dec 21, 2006 | 01:04 AM
2001TEGGSR's Avatar
2001TEGGSR
I don't know much about the smog situation, but running pig rich as your car was before you switched ECU's, will cause a malfunctioning Cat Converter.
Your not getting any CEL's right?
You might need to clean off your O2 sensors after installing the Cat, too.
Old Dec 21, 2006 | 01:24 AM
95LSv's Avatar
95LSv
Banded
Nope, not throwing any codes. The o2 sensor is not in the cat, its on the header, but yea I will clean it if that would help. I'm also going to replace the cat again. What else could cause this??
Old Dec 21, 2006 | 09:35 AM
Snoopy's Avatar
Snoopy
make sure your timing is at 16degrees tdc. your plugs are still good. and drive the car for a little while to get the cat heated up before going to smog again.
Old Dec 21, 2006 | 02:14 PM
95LSv's Avatar
95LSv
Banded
Timing is at 16*, says right on the smog report, maybe I should get new plugs, though these only have like 900 miles on them. As far as getting the car heated, I drive 20 miles to the place, so I'd say its hot enough. Do you think changing the cat would do it??
Old Dec 22, 2006 | 04:52 AM
primetime's Avatar
primetime
is your new cat oem or aftermarket? i thought that i bought a high flow cat but was sent test pipe that resembled a cat, went to emissions and failed because the cat wasn't getting hot enough, thats when i found out it was a straight pipe fortunantly one of the guys who worked there had a oem Cat and let me borrow it for the test and my gsr/lsvtec past with very low emissions.
If i were you i'd check the cat again and make sure its oem and clean the o2 sensor for the test!! when you finally get it to pass switch back to your previous set-up!!
