Not Starting
Old Nov 6, 2006 | 01:06 PM
tek0056's Avatar
tek0056
Default Not Starting
Ok, for the past couple of weeks I have had to once in a while pop start my 94 GS-R. Well last Thursday it completely stop starting, all I can do is pop start it now. Trouble shooting steps I have taking are:
1. Took out the start and had NAPA Test it (Starter is Good)
2. Checked my ignition switch by putting a test light to each soldering point, the test light lite on every key position.
I don’t know how to test my clutch safety switches. I’m thinking it must be the upper one but I’m not sure? Any Idea’s
Old Nov 6, 2006 | 01:36 PM
hachacker5024's Avatar
hachacker5024
its most likely ur clutch netural swtch. just look under the dash near the pedal and there should be a button and when u push the pedal it should push in the button so check to make sure thats good if not u can remove the wires bypass it and try to start it.
Old Nov 6, 2006 | 01:57 PM
tek0056's Avatar
tek0056
Ok, dumb question! When I look at the end of the connector it looked like it had 4 connections on the end of it...? How do I jump that, which one do I loop together?
