Itr Lsd
Old Oct 1, 2002 | 12:43 PM
PearlBlueB16's Avatar
PearlBlueB16
Default Itr Lsd
Will a stock ITR LSD fit any B-series engine? For example a GS-R or 2000 civic Si?
Old Oct 1, 2002 | 03:16 PM
Snoopy's Avatar
Snoopy
been there done that
yes
Old Oct 2, 2002 | 04:30 AM
TheRooster's Avatar
TheRooster
Former Senior Member
Default Re: Itr Lsd
Good luck trying to find somewhere that has done the swap before though. :thumbup:
Its not that hard to do yourself if you've got the Helms Manual and applicable mechanical skill/tools though. I did it in a weekend, although that was because all of the gears fell off of the counter-rotating shaft, and we put the reverse idler gear in upside down.
Old Oct 2, 2002 | 10:07 AM
PearlBlueB16
So I shouldn't trust just any shop with installing an LSD into my b16? I have a friend who's father own's a transmission shop so i assumed he knows how to install LSDs.
Old Oct 2, 2002 | 10:12 AM
qtiger's Avatar
qtiger
Any tranny shop can handle the job. Its just a different differential.
Old Oct 3, 2002 | 01:46 PM
PanaPower's Avatar
PanaPower
Default tranny info
I've put two LSD's in my car. It's not hard at all. it's time consuming. The MAJOR thing that you need to watch for is the proper shims. The tolerances have to be taken into consideration when doing this because each tranny is differences when it comes to tolerances. The LSD from an ITR WILL fit onto a GSR.
Good luck.
Old Oct 3, 2002 | 08:13 PM
PearlBlueB16
Will an ITR LSD fit a 2000 Si(B16A2)?
Old Oct 4, 2002 | 02:00 AM
RpG~^_^~LauRnO's Avatar
RpG~^_^~LauRnO
i thought HONDA didn't make SI in 2000.. or 2001 .. don't remember now
Old Oct 5, 2002 | 08:04 PM
97teg's Avatar
97teg
I know you said all b series but just checking if it will fit the b18 b too.
Old Oct 7, 2002 | 10:38 AM
TheRooster's Avatar
TheRooster
It'll fit into either the S80 or Y80 transmissions.
As far as the install goes, the only trick is preloading the tapered roller bearing. A lot of shops haven't got a clue how to do that (at least that I found). If you go with the new roller bearings that replaced the stock tapered roller bearings, you won't have that problem though. It'll just be a matter of getting your clearance set.
