Foggy Windshield
Old Nov 1, 2006 | 07:10 AM
schlitz62's Avatar
schlitz62
Default Foggy Windshield
During the winter months I have an annoying problem with my 91 Integra. It seems that in the mornings I have quite a bit of moisture on the inside of my windshield. If it is too cold, of course, I have ice.
I then have to scrape the ice (or wipe off the fog) which makes a mess on the windshield as well as the dash.
Has anybody had a similar problem and found a solution? Thanks for the help and suggestions.
Old Nov 1, 2006 | 07:42 AM
Misa's Avatar
Misa
Pic Whore
thoroughly clean the glass on the inside.... itll reduce the fog.
Old Nov 1, 2006 | 07:47 AM
reno96teg's Avatar
and found out what's causing moisture inside the car. is water getting in anywhere? check your taillight gaskets and the sunroof drainage tubes (if you have a sunroof), for starters.
Old Nov 1, 2006 | 08:41 AM
schlitz62's Avatar
schlitz62
Thanks for the suggestions; I will definitely search for the source of the moisture. Being that it is a 91 I'm sure some of the rubber weatherproofing is starting to deteriorate.
Old Nov 1, 2006 | 01:13 PM
powerofthemonks's Avatar
powerofthemonks
Ska is Life
also rain x makes a anti fog thingy to put on the windows that helped on mine and i also on sunny days park my car in the sun with the windows down to dry out the moistore inside the car
Old Nov 1, 2006 | 02:53 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Rain-x anti-fog crap doesn't work at all.
Has your windshield been replaced? If so you might have a bad seal.
Old Nov 1, 2006 | 03:24 PM
fastback's Avatar
fastback
I'd check the windshield vent cover thing's (below the windshield) screw seals too, this is a fairly common leak.
Old Nov 1, 2006 | 07:02 PM
powerofthemonks
Ska is Life
what are you talking about all of rainx products work mericals imo h:
