LS noob question
Old Oct 17, 2006 | 09:42 PM
gsr0102's Avatar
gsr0102
Default LS noob question
how much would an ls/vtec cost someone?
and is a 99 ls coupe a dc4 or a dc2? <--the noob ?
Old Oct 17, 2006 | 10:14 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Your '99 LS, like mine and any other 94-01 RS, LS or GS coupe... is a DC4.
A properly built LS-VTEC is not a cheap proposition.
Working from rough figures and assuming you're paying for all aspects of the motor build and installation, budget $2K parts & labor.
Old Oct 18, 2006 | 03:28 PM
gsr0102's Avatar
gsr0102
ok thanks
Old Oct 20, 2006 | 05:39 PM
g290ls's Avatar
g290ls
they call me tater salad
yeah its adding up to the cost of doing a gsr swap and most places do it for $2500 and up at least here anyways if you need some more info on it here is a link
http://www.sportcompactcarweb.com/te..._vtech_engine/
Old Oct 20, 2006 | 08:26 PM
gsr0102's Avatar
gsr0102
would it be better to just boost the ls?
Old Oct 20, 2006 | 08:36 PM
highspeed's Avatar
highspeed
What do you want? reliable? fast? Well if you have both done by reputable pros the turbo will cost you more I think. I have a turboed g2 teg and it smokes ls/vtecs in first gear even with it running very poorly. The ls/vtec should be done with gsr head to get just a little edge out on the competition running B16 heads, or shave the b16 head to get the compression. Hope this help some
Old Oct 20, 2006 | 08:55 PM
gsr0102's Avatar
gsr0102
well im not sure which way to go. but thanks for all the help. ill figure it out soon.
Old Oct 20, 2006 | 09:38 PM
Driverman5777's Avatar
Driverman5777
both ftw
Old Oct 21, 2006 | 12:54 AM
2001TEGGSR's Avatar
2001TEGGSR
In terms of HP for you're dollar, you will achieve higher gains if you just Boost you're LS. Peice a kit together yourself, & when you want even more power add a VTEC head to the mix.
LS Vtec without any other major mods will only gain you around 30 hp.
