hose
Old Oct 16, 2006 | 02:27 PM
mikeybaby's Avatar
mikeybaby
Default hose
Their is a hose that connects into the valve cover from the airfilter how do i disconnect that so that I can remove the valve cover?
Old Oct 16, 2006 | 02:35 PM
t3t4delsol's Avatar
t3t4delsol
it probley just stuck on there try twisting the hose if that doesnt work use put a rag on the hose and use a wrench to break it loose
Old Oct 16, 2006 | 02:36 PM
mikeybaby's Avatar
mikeybaby
what is it though do you no Im afraid to take it off ;x
Old Oct 16, 2006 | 02:38 PM
2001TEGGSR's Avatar
2001TEGGSR
It's part of the Crankcase Ventilation System. It's nothing more than a supply of fresh air to the inside of your engine. Be sure to put it back on when your done, dont put a breather on there unless you use some type of catch can setup.
Old Oct 16, 2006 | 02:47 PM
mikeybaby's Avatar
mikeybaby
alright so im going to just try to take it off then thanks
Old Oct 16, 2006 | 03:04 PM
mikeybaby's Avatar
mikeybaby
I cant seem to get the little silver end peice off its keeping it from coming off by holding it on to tightly
Old Oct 16, 2006 | 03:14 PM
t3t4delsol's Avatar
t3t4delsol
use a wrench, squeeze it tight and twist it while you squeeze,
wait are you talking about a hose clamp?
there are two prongs on the clamp use a pair of pliers and squeeze the prongs together, twist it as you squeeze
Old Oct 16, 2006 | 03:26 PM
mikeybaby's Avatar
mikeybaby
Old Oct 16, 2006 | 03:33 PM
t3t4delsol's Avatar
t3t4delsol
yeah thats a hose clamp i cant tell by the pic cause its kinda blurry, there are a couple of kinds, A. flat head screw driver, B. socket, C. pinch the peiced that stick out together
Old Oct 16, 2006 | 05:21 PM
2001TEGGSR's Avatar
2001TEGGSR
Use plyers or even a vice grip. Just squeeze them and slide the clamp a good 2 inches away.
