help!
Old Sep 30, 2002 | 03:28 PM
hollaback6's Avatar
hollaback6
Default help!
okay i'm thinkin bout just rippin out my a/c out but if i can just want to keep it. okay well my a/c needed to be charged cuz it wasn't getting cold. so we take it to spray the engine out and suddenly my a/c starts getting cold. So i charge it and it the a/c compressor starts circulating but i can't get the a/c to turn off unless i unplug the power to the a/c compressor. but now my fans stay on all the time. What is wrong with my car. is it still thinkin the a/c is on.
Old Sep 30, 2002 | 06:51 PM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
maybe it's some kind of relay that's making it run all of the time...
that's just a guess, but i saw on consumer guide that ac belts or something to that effect seem to go out
hoped that helped somewhat....
Old Oct 1, 2002 | 12:02 AM
bgood7061's Avatar
bgood7061
DO IT RIGHT THE 1st TIME
Did you check your fuses as well as your relays but inside and in the engine bay...i would get a diagnostic from a local mechanic or a dealership to find out what the problem is and if it's just a relay or fuse, just repair it yourself!!! Good luck man!
Old Oct 5, 2002 | 03:14 AM
PnX-R's Avatar
PnX-R
I'd really like to help you but you're not giving me enough information. You said your fan stays on. What fan?? I could give you a better diagnostic guess when you do give me more info..
Old Oct 5, 2002 | 04:46 PM
hollaback6's Avatar
hollaback6
the fans that cool the engine. Well i have got the fans to turn on and off now. apparently it was just a ground that was being grounded and causing them to stay on. They told me to replace the relays and that after that my a/c should work fine.
