Turn Signal Problem - Help!!!!!!!!!!
Old Oct 18, 2006 | 05:34 PM
Misa's Avatar
Misa
Pic Whore
STOP USING ALL CAPS!!!
lc
Old Oct 18, 2006 | 06:29 PM
fastback's Avatar
fastback
What I did was just remove he bulbs from the corner markers, that way the fronts blink fine and everything is OK for now. This weekend, I will be swapping out the ICU and if that fixes it, I will let you know.
Old Oct 19, 2006 | 11:06 AM
JUNGENE's Avatar
JUNGENE
thanks, I will also check to see if I could get the hazard switch and if it works, I will also let you know.
Old Oct 22, 2006 | 10:18 AM
fastback's Avatar
fastback
OK, just swapped out the ICU and that fixed everything that was going wrong on the dash on my car, so I would highly recommend that you look into this as a likely cause as well.
Note too, this was a bit of a pain in the ass to do... took me about 1 1/2hrs. Fair amount of crap to disconnect/remove to get the ICU out. I ended up removing the driver's seat so I could really get in under the dash, and that made it a lot easier.
Old Oct 31, 2006 | 11:34 AM
JUNGENE's Avatar
JUNGENE
Thanks
