weird vtec
Old Sep 26, 2006 | 12:52 PM
gsr converters's Avatar
gsr converters
Default weird vtec
i was wondering if someone can answer something for me. when i start my car up and wait until the temp gauge gets to the first or second mark, then go out onto the road and punch it, my rpm goes up to 4400 and my tires break traction. like it has a whole lot more power. when i let it warm up to temperature, it doesnt do it. anyone know why?
Old Sep 26, 2006 | 12:55 PM
Snoopy's Avatar
Snoopy
been there done that
you shouldnt get on it till it fully warms up anyways
Old Sep 26, 2006 | 12:58 PM
gsr converters
yeah i know, but when i do its got a lot more power. i let i warm up a little when i do get on it, and i dont do it all the time also the car has to be warmed up a little or the vtec wouldnt even come on
Old Sep 26, 2006 | 12:59 PM
t3t4delsol's Avatar
t3t4delsol
cars run better when the engine is colder, because there is less friction in the engine. when your oil gets hotter ther is more friction
Old Sep 26, 2006 | 01:07 PM
gsr converters
so if i hooked up my radiator fans to always stay on, id always have more power?
Old Sep 26, 2006 | 01:10 PM
t3t4delsol's Avatar
t3t4delsol
no it doent work like that
fastback's Avatar
fastback
Um, you got that one completely wrong. There is LESS friction when the oil is up to temp. Viscosity DROPS with temp increase. Why would you want more friction while you are driving????
Doesn't the car have to be at temp before VTEC will engage? I know it won't if oil pressure is too low, so maybe when the car is cold, it isn't engaging and you are getting a torque bump from remaining on the low RPM cam lobe when the secondaries open.
Old Sep 26, 2006 | 01:19 PM
gsr converters
i have a blox intake mani, it doesnt have secondaries, and i know that vtec is hitting because it does exactly te same thing when it is fully warmed up. just isnt that extra umph. if i just hop in it when its cold, and take the rpms up to where vtec is i get nothing so i know its warmed up enough to come on
Old Sep 26, 2006 | 01:27 PM
fastback's Avatar
fastback
What ECU?
Explain that? Is it switching over to the second cam profile when it is cold or not? Secondaries or not, VTEC switchover is still dependant on oil pressure.
Old Sep 26, 2006 | 01:30 PM
gsr converters
no it doesnt switch over when it is cold, only when it warms up it does, i have the stock ecu, its a 94 gsr
