I wanted to know if anyone knew if NSX calipers would fit under the stock ITR rims? and if the ITR front calipers could be used in the rear with front sized rotors?
I think it's possible with a bit of modifications... Someone on here had NSX calipers on his Civic... it was about a year or so ago when he posted though so you might have to do a lot of searching...
Not sure if it would fit inside the wheel, but I have seen the NSK caliper/rotor swap done on a Civic. It had 17's or 18's though...I want to say the Type R wheel is 16 right?
i thought they were 15's last time i saw one, then again theyre a pretty rare sight around here.
they are 15's. The JDM 4 lug (96-97) Type R's are also 15's. the 98 spec JDM Type R's are 5 lug 16's. But does anyone think the ITR front calipers will work in the rear with bigger rotors. As far as the clearance issues in the front, I'll just use DC5 Type R rims. They're 17's.
