ABS Light is on
Old Sep 23, 2006 | 07:11 AM
AcuraIntegra305's Avatar
AcuraIntegra305
Default ABS Light is on
my abs light has been on for a long time and it makes a wierd kinda loud vibrateing noise every couple min or hour i sometimes dont realize it cuz i got so used to it. so its hard to say how often, any ideas on what it could be
Old Sep 23, 2006 | 10:50 AM
fastback's Avatar
fastback
Either something is failing or you need new brakes. Have you actually checked anything yet?
Old Sep 24, 2006 | 09:50 AM
KarrNtegGSR's Avatar
KarrNtegGSR
You may need to have it scaned w/ the scan dynostic tool. I would suggest going to your local CC tech school and see if they will scan it for you for free.
Old Sep 24, 2006 | 01:11 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
i have an abs control unit and abs unit for sale if you need one.
Old Sep 29, 2006 | 06:30 PM
turbocajun's Avatar
turbocajun
Default ABS Problem
When I bought my 96 GSR the ABS unit would pump up every 5-10 minutes. The problem was a leaking accumulator (the cylindrical part on the back side of the ABS unit). I was able to buy a small o-ring from Acura and I replaced it. Problem solved. It was not an easy fix as you have to take the entire ABS unit out of the car to get to the bolts on the bottom of the accumulator to get it loose. There is no problem bleeding the unit after it is put back in (bleed the brakes like you normally would). Look for brake fluid under the ABS unit, this will indicate leakage of the unit. If you don't want to mess with it, you can just unplug the ABS unit and the brakes will operate normally, albeit without the ABS. Good luck.
Old Oct 2, 2006 | 09:27 PM
Black Ack's Avatar
Black Ack
Black Acura Driver
I had my ABS light come on after I changed out my front and rear brake pads, and brake fluid. It would come on after a short period of driving and stay on until I shut the engine off. I just took the car down to the family mechanic, had him erase the ABS error codes it was giving him, and presto! No more ABS light.
Old Oct 7, 2006 | 10:36 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
I would check the fluid in your ABS motor to ensure there is not a leak somewhere. My wife's accord did that for a bit and topping off the brake fluid fixed it.
