bout to start my clutch install...
Old Sep 12, 2006 | 03:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Air tools are overrated. I end up just shearing off bolts and nuts with them. I have yet to encounter a bolt I couldn't get off with my trusty 2' breaker bar.
Old Sep 12, 2006 | 03:58 PM
Hondaman's Avatar
Hondaman
Black Pearl
I shear them off when I don't use air tools. h:
Old Sep 12, 2006 | 04:09 PM
MTEng's Avatar
MTEng
Originally Posted by Hondaman
My tip for the job...
When removing the transmission, make DAMN sure all the sensors are unplugged and that everything is disconnected.
When installing the transmission, make DAMN sure all the wires are not in the way or get pinched between the transmission housing and the block.
I SECOND THESE TIPS !!! I also forgot to mention that you need to unplug the reverse switch prior to removing the trans from the car
Old Sep 12, 2006 | 04:24 PM
MTEng's Avatar
MTEng
You will also need something to seperate the lower ball joints on either side. You can usually rent the tools from a local auto parts store.
The SHIZZZZZNIT in ball joint tools:
Honda part number 07MAC-SL00200
Got mine from the local Honda dealer for about $60 back in 1987... I hear they're pretty pricey these days but I think they're available. Worth the money !!
Old Sep 12, 2006 | 04:52 PM
Provocateur
On permanent hiatus
And the speed sensor.
Old Sep 12, 2006 | 08:23 PM
pinealean's Avatar
pinealean
All very good advice. Thanks everybody for the input.
I remember taking the axles out in my crx long ago and I just banged on the control arm until the joint came apart. I always wondered if it was bad for the car? I will make for positive absolutely sure that I have all connections to the tranny disconnected before I make an attempt at taking it apart. I'm pretty paranoid about things and so I usually check stuff several times before tearing stuff apart. Anyways, if I have any trouble throughout the process I will post it. Having backup from fellow Teg owners gives me piece of mind. Thanks again.
Old Sep 13, 2006 | 05:43 AM
MTEng's Avatar
MTEng
I leave that hooked up and dangle the trans from it as I switch out the disk. That way I don't have to lift the heavy trans off the floor and risk injuring my back
Old Sep 14, 2006 | 03:06 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
(long time since i've been here.)
like some have said, it's simple, just go by the books, take your time and use your head.... best of luck!!
here's my super old summary of when I did what you're doing! =P
https://www.honda-acura.net/forums/s...d.php?t=206669
Old Sep 14, 2006 | 02:19 PM
pinealean's Avatar
pinealean
Default ball joints froze!
I cannot get either ball joints to break loose. I was hoping to get them off without the too, but I may have to get one. I tried jacking up on the castle nut which did nothing but lift my car up off the jacks. Does anybody have any suggestions?
Old Sep 14, 2006 | 04:49 PM
pinealean's Avatar
pinealean
nevermind! I had to rent a fork set. I really had to bang on em. All the grease squished out of the boots and one of them ripped. I hope it's no big deal to fix that. I couldn't get the shift pin out, so I disconnected it at the shifter hoping that will work. Now I gotta get the axle nuts broken. I know I should've done that first thing, but didn't think bout it. I know they're on torqued on there pretty good. I couldn't get em off with my wrench, so I'm waiting for a buddy to bring a breaker bar over. I'll keep posting as if I run into anything to bitch about.
