engine temp?
Old Sep 6, 2006 | 06:22 PM
powerofthemonks's Avatar
powerofthemonks
Ska is Life
Default engine temp?
on the way home today while sitting at a red light i noticed that the engine temp begain to grow but once i started traveling again it went back down to normal temp then the next red light a long one (about 1-2 mins) the engine temp went all the way to the red line before i shut it off and waited for the light to turn green. after a 30 min drive down the interstate on the way home everything seemed fine but once i begain idleing again in my parking lot the temp started to rise again..... what could be causing this i check and both the fans were running and oil level is fine (ill change it tomorrow just incase) the engine is to hot for me to check the radiater fluid but i have never had problems with it leaking (ill check it in the morning)
its a 91 stock ls with 112k belt and water pump was changed at 90k
i am a broke college student and this is my only car that i need to get to school any suggestions? thoughts? comments?
thanks
Old Sep 6, 2006 | 07:29 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Is there anything physically blocking the radiator from getting airflow; ie plastic bag etc.??? Has the thermostat been changed???
Old Sep 7, 2006 | 07:45 AM
powerofthemonks
Ska is Life
no and no i was leaning towards the thermostat as the sourse but wanted other opinons
thanks for your input
Old Sep 7, 2006 | 02:53 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I recently replaced the thermostat in my '94 Accord because I was having the same problems. The car would overheat after idling at lights but the temp would drop back down when I started moving again. Since replacing the thermostat, I haven't had any issues with this. It seems to be working at normal operating temp now.
Old Sep 7, 2006 | 03:16 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Themostat is probebly stuck. Replace and it will be better.
Old Sep 7, 2006 | 03:28 PM
powerofthemonks
Ska is Life
just finnished replacing the thermostat i just about to take a test drive
thanks for you guys' help
