new clutch problem..HELP
ok i installed my new exedy clutch stage 1 along with a lighten flywheel..installation went fine..started up the car..started up fine..i let it idle for alittle..now tried to shift into gears it would not..it would go into gear but very hard to shift into gear..what could it possibly be, did i install the clutch wrong.? if i did would the car even start up?...slave cylinder?..MC?..i bleed the clutch line..but no diffrent maybe just very little diffrence..unless i did the bleeding part wrong..HELP
