Question
Old Aug 27, 2006 | 02:27 AM
NwAmH's Avatar
NwAmH
hatch that gets snatch
Default Question
I am changing my block on a b18b, because it developed a crack drilling out a bolt on it. Basically I will be taking all the internals of the cracked block and pla\cing them in the new one along with the head. Now my questions is; is it neccessary to replace rings and bearings and head gasket, if they are in good condition?
Old Aug 27, 2006 | 07:37 AM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
why not replace them?? its cheap insurance against having spun a bearing or something else going wrong and having to replace the bottom end again.. sure they may measure up to specs and all, but i would definitely replace them anyways..
Old Aug 27, 2006 | 08:49 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The headgasket and rings are required to be replaced. The bearings are optional, but I would definitely consider it.
Old Aug 27, 2006 | 08:58 AM
2001TEGGSR's Avatar
2001TEGGSR
Why cut corners with the block torn appart anyway? You'll deffinately appreciate doing it now rather than start burning/leaking oil down the road. Always, Always replace rings & gaskets when you have your enigne appart too. I would replace the bearings too but thats just me.
Old Aug 30, 2006 | 04:42 PM
Tobra's Avatar
Tobra
Do it once, do it right, replace them
