best turbo to use on a da
Old Aug 16, 2006 | 03:19 PM
g290ls's Avatar
g290ls
they call me tater salad
Default best turbo to use on a da
what would be a good set up to run a on a da with a b16?
Old Aug 16, 2006 | 04:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Your question is too broad. Narrow down your budget, built specs, and power goals and it would be a little easier to recommend one.
Old Aug 17, 2006 | 10:49 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
t66 .68
Old Aug 17, 2006 | 01:55 PM
sherwood's Avatar
sherwood
I missed Sean
just sell him yours, now that you are in CO it's about time you upped the ante.
Old Aug 17, 2006 | 05:19 PM
Provocateur
On permanent hiatus
I would, especially since there are no smog regulations whatsoever, but the funds are holding me back.
Old Aug 17, 2006 | 05:29 PM
sherwood's Avatar
sherwood
I missed Sean
don't forget to tune your engine again.. the air in grand junction is probably cooler in the winter and might suggest a re-tune
my buddies sti FMIC is basically touch warm if that on the output side in the winter months, and this is with a massive turbo pushing 300 horse with the wastegate stuck open. you might start getting problems with a lean tune once winter hits
:edit:
on a 30 degree night last winter i touched the FMIC on the outlet side after he was driving for about an hour, it wasn't even warm and he still had the engine running
Old Aug 17, 2006 | 05:35 PM
Provocateur
On permanent hiatus
:edit:
I am going to need to retune anyway. Since the elevation is different (4500 ft compared to sea level), air is thinner, so the turbo spools later, it pulls less vacuum, and the car runs richer than it did back in California.
Once I get all my stuff on this side, I will retune it and see if I can get some power back.
Old Aug 17, 2006 | 05:36 PM
sherwood's Avatar
sherwood
I missed Sean
didn't think about that h:
Old Aug 25, 2006 | 12:05 PM
g290ls's Avatar
g290ls
under $2k? i have looked at garrett and they seem to be the only ones i would be able to do it with my specific setup and im looking for something thats boost that i can take to the track and still be a daily driver
Old Aug 25, 2006 | 12:17 PM
Provocateur
On permanent hiatus
$2k isn't enough for a reliable turbo setup on a daily driver.
