Brighter headlights
Old Aug 3, 2006 | 02:26 PM
DezertMachine's Avatar
DezertMachine
Default Brighter headlights
I was wondering how I can achieve brigher headlights. My low beams are pretty weak ,but I feel like an asshole when I drive with my brights on.
Old Aug 3, 2006 | 02:28 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Do an HID conversion.
Old Aug 3, 2006 | 08:31 PM
Kai's Avatar
Kai
Rotorphile.
As long as the housings are clean, try some Silvania Silverstars. Bright and perfectly street legal.
Old Aug 4, 2006 | 04:45 AM
jjang's Avatar
jjang
get a 9005 conversion. i had it on my gsr when i had it. its much brighter, not as bright as HID's but its cheap.
get 9005 bulbs and make them fit into your 9006 (low beam) sockets. u just have to clip the plastic slits on the inside of the bulb where u plug it in. i used needlenose pliers. takes 5 mins
Old Aug 4, 2006 | 06:37 AM
sherwood's Avatar
sherwood
I missed Sean
werd 9005 conversion is a pretty good el-cheapo option.
Old Aug 4, 2006 | 08:03 AM
DezertMachine
Are you saying just convert the 9006 bulb to a 9005 bulb? How do I do that?
Old Aug 5, 2006 | 02:20 AM
jjang's Avatar
jjang
buy some 9005 bulbs.. compare it with your 9006 low beam bulbs. youll see what you need to do. there are two tiny plastic pieces in the 9005 bulb that need to be cut out/broken off. im sure theres more specific details in other threads.
Old Aug 5, 2006 | 02:29 AM
DezertMachine
Hmm...ok I'll try it.
Old Aug 5, 2006 | 09:05 AM
96GsR06's Avatar
96GsR06
do you need to do any mods for HID bulbs, or what?
Old Aug 5, 2006 | 09:30 AM
sherwood's Avatar
sherwood
I missed Sean
to use hid bulbs you will need a hit conversion kit. everything you need to know is outlined on Team-integra.net in the articles section. honestly most of the questions asked here are answered there so it's best to check them before asking.
as far as the 9005 conversion goes, you might also think about installing a set of fog lights. fog lights are usually so low that no one cares when you have them on, but they are so bright that they help you see. it's really likie having a high beam mounted at the lowest point possible.
might want to think about it
