PS pump whining....
Old Jul 15, 2006 | 09:34 AM
pinealean's Avatar
pinealean
Default PS pump whining....
I replaced my timing belt last week and since then I've been hearing this whine. I figured it may be the Tbelt tension, so this morning I set out to adjust it. Long story short, I used a screwdrive to ear to locate the sound. It was loudest when I touched the PS bracket. So, I took the PS belt off and started the car and the noise went away. I put the belt back on and the noise persists. I adjusted the tension several times from tight to loose and the noise remains.
So, this must be a sign of PS pump failure right? I don't think it can be the belt itself. I read a post that mentioned rebuilding the PS pump rather than buying a new one. What is involved in this process? Anybody else face this before?
Needless to say I am relieved that it wasn't my Tbelt. I didn't want to tear all that out again.
Old Jul 17, 2006 | 05:45 PM
awormofearth's Avatar
awormofearth
sho nuff
Is it only when you're turning that you can hear this whine? If so, I have a similar problem. I've got a minor oil leak, and when oil touches the PS belt, it starts to whine sometimes. I wouldn't replace the belt if it has oil on it, unless you've stopped the leak first, or it will just do it again to the new belt eventually. A squeal could also just mean that something isn't lubricated enough.
Old Jul 17, 2006 | 06:02 PM
pinealean's Avatar
pinealean
The sound doesn't change when turning the wheel. It's just constantly there. Seems not quite as bad when the engine is cold, but dont really know. I do know that when I had the belt off and started the motor I couldnt hear it, so i'm inclined to believe that it's the pump. Anyone with similar problem? Can I just replace a bearing?
Old Jul 21, 2006 | 05:09 PM
g290ls's Avatar
g290ls
they call me tater salad
have you checked the fluid recently?
