Help with OBD1
Ok, I searched for the ELD Sensor. Can a bad starter throw this code? I know it takes a couple of tries until it finally cranks over, otherwise it just clicks.
MAP sensor causes rough idle.
and IACV causes jumpy idle when hot.
So... I will reset the ECU using the Back-Up Fuse technique, drive the car around the block and check my codes again.
It seems like I'm talking to myself but others can read and it helps me remember what I was thinking
MDPL8706
MDPL8706
