Burning..
Old Sep 24, 2002 | 05:54 PM
Grim's Avatar
Grim
Default Burning..
newbie question..not to be flamed! This is kinda a general question not really about integras, but I was test driving a 95 gsr, and I noticed a faint burning smell after accellerating out of big stops. It went away fairly quickly but happened almost every time the car came into and out of a stop.
Is this general indication of a specific problem? Possibly a worn clutch? The guy said it had something to do with the brakes not being used often (car was not a daily driver). What do you guys think?
Old Sep 24, 2002 | 07:51 PM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
could be the oil burning, coolant burning
i don't know as far as the brake situation
Old Sep 24, 2002 | 08:22 PM
g2tegls's Avatar
g2tegls
MR, ftw
Brakes burn? Yeah, I'd stay away from any car that smells like it's burning when you test drive it. You wouldn't be able to smell the oil burning from inside the car, unless you had a window open, you might catch a slight scent once in a while. My car burns oil. The only time I've ever smelled something burning strongly was when I had an electrical problem. Smoke was actually coming out the air vents. That wasn't good. You would probably be able to smell a clutch burning but it shouldn't be burning unless you are burning it. A worn clutch doesn't smell. A burning clutch does. I've burned my clutch before too. HTH
Ben
Old Sep 26, 2002 | 08:27 AM
mrhonda_187's Avatar
mrhonda_187
Could have been the brakes; no, they don't 'burn' but there is an odour when you're on them hard. But, if you were on the car that hard during a test drive, the seller should have kicked your a$$. Don't know... I wasn't there to smell it. Had I smelt it, I could have told ya.
Old Sep 26, 2002 | 08:51 AM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
maybe it was the clutch....
Old Sep 26, 2002 | 08:55 AM
antarius's Avatar
antarius
Large Member
Clutch smells, ick.
That smell gets to the back of your throat.
poooooey
Old Sep 26, 2002 | 09:39 AM
Grim's Avatar
Grim
turns out it was just a tiny oil leak in a connector, will be a nothing. I ended up buying it. 95 black gsr 5800bucks.. its pretty mint too..jus a tiny spot or two on the body
Old Sep 26, 2002 | 09:54 AM
antarius's Avatar
antarius
Large Member
Nice, congrats.
Welcome to the community.
Old Sep 26, 2002 | 10:31 AM
kfar09's Avatar
kfar09
how many miles?
Old Sep 26, 2002 | 02:40 PM
Grim's Avatar
Grim
*shrugs* 96k. supposedly mostly highway commute miles, if that matters, was a one owner, and the guy took good care of it
