CEL Light not blinking
Old May 17, 2006 | 08:54 PM
BRAiN8's Avatar
BRAiN8
Default CEL Light not blinking
Ok, so my car has been cranking and not starting. So I replaced the ign. coil and it wouldn't crank as well anymore. Not sure what happened but that's not what I'm getting into right now.
So after that, the engine light comes on when I turn the key to "II" i believe. The light comes on only once for few seconds then shuts off. I would say that it's the "long" blink. Could I assume this to be code 10?
However, when I try to do a CEL test, via paperclip into the blue connector, the light comes on but does not blink and does not go off. Any ideas?
Old May 17, 2006 | 10:49 PM
sbreland73's Avatar
sbreland73
(Some) "Rice Inside"
Your "CEL" or MIL (Malfunction Indicator Lamp) is functioning normally. If after inserting "paper clip" you do not get any blinks, that means the ECU has no codes for you. Recommend checking the basics, i.e. spark @ the plugs, signal pulse @ the negative side of the coil, fuel @ the rail, etc. Replacing parts at random without doing a proper diagnososis can get real expinsive......................
Old May 18, 2006 | 02:02 AM
R_Squared's Avatar
R_Squared
LEVEL UP
A CEL code 10 (IAT temp sensor) would not prevent the car from starting. I've been throwing that code for forever now...
Old May 18, 2006 | 04:01 PM
sbreland73's Avatar
sbreland73
A code 10 would be 10 actual short blinks, numbers after that are represented by a short blink folwed by a long, i.e. = 14 (Idle Air Control Valve) would be one long blink, very short pause, & 4 long long blinks
Old May 18, 2006 | 04:05 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
wrong...
the 10's are long blinks and the 1's are short blink so
10 = bliiiinnnkkk
34 = bliiiinnnkkk blinnkkk blinnnkkk blink blink blink blink (pause)
Old May 18, 2006 | 06:03 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Originally Posted by tegbooster
wrong...
10 = bliiiinnnkkk
exactly. h:
