reat strut flang bolt
Old May 17, 2006 | 02:58 PM
slvrteg's Avatar
slvrteg
big boys toys
Default reat strut flang bolt
I am putting struts and springs on my 2001 gsr. I ran into some problems with the rear strut flang bolt. The flang bolt that connects the bottom of the strut to the lower arm. I can not get it to loosen. The rubber bushing won't allow it to turn. I already broke the head off of the drivers side and don't really want to break the passenger side. Any suggestions or experience based help. THnx
Old May 19, 2006 | 01:28 PM
m735is's Avatar
m735is
PB Blaster the snot out of the unbroken one. Use some heat if needed also.
Good luck! I snapped both mine off.
I had to sawzall the bolts to get the shock off, then replace the bushing. New OEM bolt loaded with antiseize.
