1999 Integra Auto Transmission problems...
Old May 15, 2006 | 09:21 AM
prelude2005's Avatar
prelude2005
Default 1999 Integra Auto Transmission problems...
Hello!
I went to autozone today to pull the check engine code that recently flashed on today. The scanner pulled two codes...
P0700 Automatic Transmission Control System
P0740 Problem in Lock-up Control System
So it could be either or both as a potential problem.
I do have tranny problems, for some reason when the car changes gears it seems like it jerks and has a hard time shifting, fluid has been replaced but still no effect.
My question is, is this seem like an electrical problem? Can I fix this myself? "Control system" seems like it is an electrical issue.
Also, if it is fixable by myself, were are these parts located?
Thanks in advance!
charlie
Old May 15, 2006 | 01:40 PM
prelude2005
Anyone?
Old May 17, 2006 | 05:40 AM
brig's Avatar
brig
I just bough a 99 Integra and am having the same problem. I had the tranny serviced whaen I bought it, about a week ago. It has been shifitn g kinda hard and this morning the check engine light came on. I can't offer advice to you, just comiseration I guess.
Old May 17, 2006 | 10:42 PM
sbreland73's Avatar
sbreland73
(Some) "Rice Inside"
According to AllData, your shift solinoids are acting up. Honda Motor Corp TSB advise to replace soliniods first. If that does not cure, then chunk a new transmission
