considering boost
Old May 15, 2006 | 07:41 AM
JLO's Avatar
JLO
7M-GTE!!!! "U-BLOC BITCH"
Default considering boost
I know this question comes up all the time,
My 96 rs has 140k miles on it very very strong engine, will I run into major problems if I boost it or should I be ok? Ive been told the b18 block is a realy strong engine and should be able to take it.....Im only lookiing to be running about 7psi of boost....
Old May 15, 2006 | 07:56 AM
Nors's Avatar
Nors
倍力恋
compression test and if you have low compression in any cylinders.. leak down test
Old May 15, 2006 | 09:13 AM
rugsr's Avatar
rugsr
How do my taillights look
do a compression test. takes 20mins, easy as balls to do, and it will save your $$$$$$$ and time in the long run
Old May 15, 2006 | 10:07 AM
Joe's Avatar
Joe
you didnt do it :chuckles:
yeah make sure your engine is strong before going turbo.
Old May 15, 2006 | 06:17 PM
g290ls's Avatar
g290ls
they call me tater salad
yeah, i agree
Old May 16, 2006 | 04:43 AM
JLO's Avatar
JLO
Originally Posted by g290ls
yeah, i agree
Im taking it in tomorrow to get checked out .....is boost bad for the engine?
Old May 16, 2006 | 05:56 AM
Nors's Avatar
Nors
倍力恋
If the engine is in poor condition yes. But if run properly, on a well maintained engine, no, I wouldn't say its bad for an engine. Unless you do rediculous things like run a lot of boost on stock internals.
Old May 16, 2006 | 07:43 AM
g290ls's Avatar
g290ls
its not a bad setup, for how much you plan to run, but i would highly consider doing the internals down the road....
Old May 16, 2006 | 09:17 AM
JLO's Avatar
JLO
which internals should be switched up
Old May 16, 2006 | 07:14 PM
1turbodc2's Avatar
1turbodc2
got boost?
your bottom end and depending on how much u wan to boost u may want to sleave yoru block to handle more boost
