D16A1 DOHC...sTuMpEd!!
Old Apr 25, 2006 | 03:11 PM
Adern's Avatar
Adern
Default D16A1 DOHC...sTuMpEd!!
88' Integra 5spd man. 108,000miles...
Code 17-Speed sensor...Speedometer is working fine. Highbeam, Check engine and battery indicators are on.(Guage cluster) Squeeky Grinding noise coming from camgears area!...Idle is eratic...Power steering is out too!! WTF!!
Why would a code 17 cause these problems?
I recently installed a new dizzy. Faulty dizzy??
The car was running PERFECT before this...No smoke no mods no Nothing!!
Any info would help.
Thank you.
Old Apr 26, 2006 | 03:37 AM
Adern's Avatar
Adern
Anyone???:hsdunno:
Old Apr 26, 2006 | 12:10 PM
Phateless's Avatar
Phateless
S2K compatible
sounds like you need to start poking around for electrical stuff. you may want to grab yourself a multimeter and a helms manual. i've heard that a bad ground can cause unpredictable behavior... maybe start there? hopefully some of the more experienced folks will chime in.
Old Apr 27, 2006 | 06:54 AM
Adern's Avatar
Adern
I'll try that out...Just sux because I'm in the process of moving right now.
I'm gonna swap out the dizzy since I still have warranty on it...I been hearing that the tensioner may be causing the squeeky/Grindin noise too.
Dunno??
I'll prep the "O.R." once I'm settled in.
Thanks.
-Adrien
Old Apr 27, 2006 | 07:26 AM
Phateless's Avatar
Phateless
S2K compatible
no prob. do some searching on this site and on honda-tech, you might find something good.
Old May 3, 2006 | 06:16 AM
Adern's Avatar
Adern
All of the pullys arent spinnin!!!!!...just noticed it...Missing a bolt out of the bottom pully!! I was told that I need a new Woodruff key and crank pully bolt!...What's the best way to get to and remove the crank pully?
Thanks.
