Obd-2---->obd-1
Old Apr 10, 2006 | 10:54 AM
Integra89's Avatar
Integra89
Default Obd-2---->obd-1
I currently have an obd-2 ecu and would like to get a obd-1...what kind of obd-1 should i get...? i have an 98 ls...
Old Apr 10, 2006 | 11:10 AM
FooD2000's Avatar
FooD2000
Still Water
i'm assuming you looking for an obd-1 so that you can chip/tune?
A p28 will work for you and it's cheaper then p72.
Old Apr 10, 2006 | 12:27 PM
a_integra_87's Avatar
a_integra_87
Traction, WTF is that?
He dosent even need a p72 for a non vtec motor. Just get a obd1 p75, unless you plan to chip it right away then use whatever you want...im using a phearable.net chipped p06 ecu, i believe thats from a d15 or something? on my 97 ls
Old Apr 10, 2006 | 02:14 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
you will need an obd2 to obd1 harness off ebay or somewhere and an obd1 p75 ecu
Old Apr 10, 2006 | 07:26 PM
Integra89's Avatar
Integra89
so what would be best...p75 or p28? for dyno tune?
Old Apr 10, 2006 | 07:37 PM
Integra89's Avatar
Integra89
and does it matter if it has come from an automatic car? if i have 5spd? what about a p06? sorry im new at this
Old Apr 10, 2006 | 08:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You want a 5 speed ECU either vtec or non vtec. Unless you have a chip with the proper LS map burned onto it for your engine, you are limited to only an OBD1 P74/P75.
Old Apr 10, 2006 | 09:51 PM
Kai's Avatar
Kai
Rotorphile.
The P06 is a peice of junk SOHC Civic computer... 92-95 DX/LX D15B7 specifically. Your car will not run properly with that computer.
Why do want to backdate, anyway? It will only make the car run less efficiently with no advantages unless you have the OBD1 computer modified for Hondata or similar.
Old Apr 11, 2006 | 11:11 AM
Integra89's Avatar
Integra89
i want to be able to dyno tune it, with obd-2 it is not possible so i need an obd-1
