b18c swap
Old Apr 9, 2006 | 12:43 PM
Ricer90's Avatar
Ricer90
90 teg LS
Default b18c swap
will a b18c swap onto a 90 ls tranny what all do i have to do is it really worth it for 40 extra hp over the b18a1
Old Apr 9, 2006 | 02:10 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The B18C will physically bolt up to the Y80 transmission, but the shorter ratios of the ITR S80 tranny are what maximize the potential of that motor.
Using your LS transmission is a bad idea from the standpoint of performance.
In all honesty, I'd recommend turbocharging your stock motor and swapping to the S80 GSR gearset. I don't know Washington emissions law; you may have to go "renegade" and smog your car through a "hookup" if WA is as strict as CA.
Old Apr 9, 2006 | 02:36 PM
Ricer90's Avatar
Ricer90
90 teg LS
so ur saying keep the b18a1 and get a gsr tranny will it bolt up the same? thanxx dave
Old Apr 9, 2006 | 03:52 PM
TheOtherDave™
Apathy Kills
If you turbocharge your stock motor, yes... swap to the GSR gearset.
EDIT: Wait a minute... is your clutch hydraulic or cable actuated?
I own a DC4.. and I get a little foggy on the second-gen Tegs. h:
But given your current N/A setup, there isn't an urgent need to swap transmissions IMO.
Old Apr 9, 2006 | 05:21 PM
Ricer90's Avatar
Ricer90
90 teg LS
its cable i do plan to boost my car what year of gsr are compatable
thanxx dave
Old Apr 9, 2006 | 05:22 PM
Ricer90's Avatar
Ricer90
90 teg LS
is the gsr gear raito longer or shorter? redline difference?
whats imo?
Old Apr 9, 2006 | 05:31 PM
TheOtherDave™
Apathy Kills
whats imo?
IMO = In My Opinion.
The GSR gears are shorter.
Take a look at the Integra FAQ Thread; the trans ratios are listed by year and by model.
Redline is a limitation of the motor.
And yes, the B18C1 and B18C5 motors rev higher than the B18B1 motor.
But you knew that already.
Old Apr 9, 2006 | 08:23 PM
Ricer90's Avatar
Ricer90
90 teg LS
right on dave thanxx 4 everything
will the gsr tranny bolt up to my cable clutch
Old Apr 10, 2006 | 01:19 AM
Brar's Avatar
Brar
G3 GSR tranny is hydro. G2 is cable so you will need a conversion kit and convert everything.
So no, UNLESS you get the hard to find YS1 GSR tranny. This is the tranny that came with the G2 GSRs. Hard to find and make sure you dont get the LS version of the YS1.
Easier to go with the G3 GSR tranny, but cheaper to get the YS1...
Old Apr 10, 2006 | 07:57 AM
u could go for a cable to hydro conversion or hydro to cable :eek3: either way its too much of a pain in the ass to go through just to get a Type R in there.... Boost as david said h: yeah i called u david...what are u going to do about? :uhhok:
