Upgraded MAP?
Old Apr 5, 2006 | 06:54 AM
rugsr's Avatar
rugsr
How do my taillights look
Default Upgraded MAP?
I believe the stock MAP on the GSR can read 10psi max. If i run 10psi daily and get a spike in boost for some reason the computer wont see the air coming in and wont and fuel......which will blow the motor tight? WELL ant aftermarket MAP i can get that will let me ready something like 20psi'ish for future upgrades and psi increases? BTW how hard are they to install and WHERE IS IT. thanks guys
Old Apr 5, 2006 | 07:30 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
20 psi on your stock motor.....Ummmm No
Old Apr 5, 2006 | 08:25 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
3 bar MAP sensor.
I am running 11 psi on the stock sensor. It maxes out at 11.2 psi. A boost spike won't affect anything unless it is a pretty large one. I have spiked up to 12.6 psi and there was no CEL.
I have a 3.5 bar Zeitronix MAP sensor that will be put in when I decide on rescaling all the maps and retuning.
Old Apr 5, 2006 | 08:26 AM
Provocateur
On permanent hiatus
He never said 20 psi on a stock motor. Reading > you.
Old Apr 5, 2006 | 09:47 AM
rugsr's Avatar
rugsr
so for now is there even a reason to get a 3bar MAP? should i just wait till i build the block. ill be driving it on 10psi daily.
Old Apr 5, 2006 | 10:43 AM
Provocateur
On permanent hiatus
I would wait. 10 psi will be pushing it with that turbo.
Old Apr 5, 2006 | 11:00 AM
rugsr's Avatar
rugsr
you mean 10psi is pushing the motor. ive heard of the sc61s handling 16psi+
Old Apr 5, 2006 | 11:58 AM
Provocateur
On permanent hiatus
Yeah, that is what I meant. h:
