few questions about oil pan gaskets.
Old Apr 2, 2006 | 06:07 PM
Integra215's Avatar
Integra215
Default few questions about oil pan gaskets.
i have a 94 integra LS
i found that my pan is leaking from the gasket.
when i took a look at the pan bolts, all of the bolts
are accessable except for the 2 or 3 bolts next to the trans.
There is a metal plate from the trans. that is blocking over the
2 bolts in the pan.
1.Has anyone else come across this? and what did you do about it?
2.Do i need silicone sealant if iam using a rubber gasket?
Old Apr 2, 2006 | 07:40 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
1. ask shmoo/gssr, they have both gone through replacing the oil pan gasket... along with several other people on here
2. yes, you wanna use either "hondabond" or the grey sealant stuff you can pick up at autozone/pepboys (or your local autoparts store)
Old Apr 2, 2006 | 08:23 PM
EH339's Avatar
EH339
To get full access to the oil pan bolts, you need to drop the manifold. Otherwise, be careful and don't overtighten the bolts, because if you do, it will leak again.
Old Apr 2, 2006 | 10:11 PM
stemyluv69's Avatar
stemyluv69
yes, there is a metal plate covering the flywheel. Should be 4 bolts. Just gotta pop those off and the place comes off. Then you have access to all the pan cover bolts. As far as sealants, the grey stuff works well- only around corners and around that metal plate
Old Apr 2, 2006 | 11:05 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The engine stiffeners need to come off to get the flywheel plate out (GSR only, I believe). That will give access to the 4 nuts/bolts that you couldn't get to.
The gray sealant at any parts store is identical to Hondabond. I have been using that stuff forever and it works very well. I slathered my oil pan gasket with gray sealant front and back with a knife and as long as the bolts are tightened correctly in a criss cross fashion, it won't leak. Too bad I am still leaking because of an old rear main seal.
Old Apr 3, 2006 | 05:31 AM
rugsr's Avatar
rugsr
How do my taillights look
i thought you didnt need to use hondabond on the oil pan gasket?
Old Apr 3, 2006 | 08:11 AM
Provocateur
On permanent hiatus
You don't have to, but I used it and it reassured me it won't leak.
