Need help with 91 Integra
Old Mar 30, 2006 | 04:03 PM
chop315's Avatar
chop315
Default Need help with 91 Integra
I just bought a 91 Integra my first acura the alt is seized and both axle shaft boots are ripped the question I have is that do new axles come with inner rubber boots? when I tryed to pull the driver side axle out 2 bearings fell out from the ripped inner boots can anyone walk me though this? thanks
Old Mar 31, 2006 | 07:22 AM
schlitz428's Avatar
schlitz428
My daughter has a 91 teg and I replaced both half shaft CV axles and was surprised at how smooth it went. I think I had to fork out the cash for a socket to fit the axle nut but still better than taking it to a shop.
This link has some pretty good (although generic) instructions. http://www.raxles.com/install.htm
Old Apr 1, 2006 | 01:51 PM
g290ls's Avatar
g290ls
they call me tater salad
i have a 90 and yes they come with new boots...saves you that much more if you do it yourself too
Old Apr 1, 2006 | 02:56 PM
chop315's Avatar
chop315
Default thanks you guys
Im trying to do it my self I have to other problems with the car first the timing belt the car has 126,000 and I have on ideal if it has ever replaced
also a power line is leaking pretty bad so im going to need to replace that also I bought the car for $300.00 still not a bad deal I guess and yes
three hundred dollars not $3000.00
Old Apr 1, 2006 | 04:17 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
that's impressive... a way to check if the T-belt was replaced, pull off the valve cover and look at the condition... if it was replaced (like it was supposed to be at 90k) then it would have almost no wear. If it wasn't ever replaced, your car is a rolling time bomb and i would suggest doing it ASAP
Old Apr 1, 2006 | 06:34 PM
Philip_Freda's Avatar
Philip_Freda
I want an NSX
If a shop replaced the timing chain there should be some kind of sticker showing when it was replaced and the mileage
Old Apr 2, 2006 | 01:21 AM
tegbooster's Avatar
tegbooster
^thats if a shop did it... if the guy that owned it before him is anything like me... he'd wanna change the t-(belt not chain) himself
