93 swap question
Old Mar 23, 2006 | 04:12 AM
Redlinerz's Avatar
Redlinerz
Default 93 swap question
was up everyone! I am swaping a 95 obd-1 gsr motor into a 93 integra. They are both obd-1 so I guess it should wire right up. What about the axels? What axels do I need? 93 ones or 95 ones? Also the shiftlinkage? The tranny is getting swapped to with a 95 gsr hyrdo one. I got the cable to hydro kit shit already. And also I am using the gsr intake manifold is that gonna work? And do I need to replace the throttle cable?
So to sum it up I need to kno which
axels
shift linkage
throttle cable
do i need 93 one or 95 one?
thanks
Old Mar 23, 2006 | 05:00 AM
Kai's Avatar
Kai
Rotorphile.
Axles: original '93
Linkage: '93
Throttle cable: not sure.
Butterfly intake manifold: 94-95 GS-R P72 computer, add the wires for the butterfly plates and VTEC.
Old Mar 24, 2006 | 09:23 AM
Redlinerz's Avatar
Redlinerz
thanks kai... i juss pulled the 93 ls motor out and am tryna bolt in the 95 gsr motor.. what mounts am i soupposed to be using?? so far i have been told be numerous ppl and sites such as g2ic.com that i use my stock b18a1 mount.. well for the tranny mount it isn't working. The bracket isn't bolting up to the tranny.. any ideas guys? thanks
Old Mar 24, 2006 | 04:23 PM
Kai's Avatar
Kai
Rotorphile.
Hydro and cable transaxles have different mount points.
Old Mar 25, 2006 | 05:09 AM
Redlinerz's Avatar
Redlinerz
well i had to use a lil imagination but i think i got it to work... i used the 95 gsr mount .. it bolted up to the tranny perfect (cuz it is for that tranny) and it was juss a lil too big for the frame side of the mount so i had to bend it and make it a lil bigger.. there is nothing you cant do without a torch and a mallet :-) .... now the motor on the tranny side is sittin a lil high but i hopefully when i put the hood back on it will close.... now my next question.. i want to try and run these hydro lines and switch the pedals.. i also have a 94 civic hatch.. you think i can use the pedals, lines, and slave cylinder from this???? also how manyu lines are there??? thanks for all the help
Old Mar 25, 2006 | 05:12 AM
Kai's Avatar
Kai
Rotorphile.
The clutch system only has one line from the master to the slave cylinder.
As for swapping hardware, you're on your own.
Old Mar 25, 2006 | 06:07 PM
Redlinerz's Avatar
Redlinerz
so wha do i need to swap??? i juss need to run the hydro line? where does it go to? i heard i need to swap the brake booster assembly and pedals
Old Mar 26, 2006 | 10:35 PM
Kai's Avatar
Kai
Rotorphile.
Did you buy a conversion kit or just a bunch of parts? Without the kit, you need a slave cylinder, the line, master cylinder, figure out a way to mount the master, and change to a clutch pedal that connects to a master cylinder.
