Found the leak!!!
Old Mar 12, 2006 | 12:20 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
what did u look up to get the second pic? i have looked under just about everything????
also the sunroof diagram looks like it has a drain in the front and one in the back... is this true or is there 2 in the back?... i have water building up in the pass front corner of the sunroof and leaking down also.
Old Mar 12, 2006 | 06:08 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
no pics tonight cause my g/f has my digital camera. i took the trim and squeezed it to make it tight and put it back on it but it still leaks. i will post a pic tomorrow night.
Old Mar 12, 2006 | 07:39 PM
reno96teg's Avatar
"pillar garnish"
sounds like your sunroof drainage tubes are clogged. clear them out. that will probably take care of everything..
Old Mar 13, 2006 | 10:49 AM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
the sunroof drainage... is there one on the front and one on the back? and how do i get to them?
Old Mar 13, 2006 | 08:03 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
this is where i am talking about.
Old Mar 14, 2006 | 05:14 AM
reno96teg's Avatar
it's doubtful that water is getting in through there. like i said, it's most likely your sunroof drainage tubes. you'll probably need to blow compressed air through them to clear them out.
i'm not certain on how to access them, as i don't have a sunroof myself. it's a common issue though. search the forums and you should find something.
hopefully someone will chime in with their experience..
Old Mar 14, 2006 | 10:01 AM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
well the sunroof is stopped up. and the water in the floor is coming from the door jam. i washed my car and looked from the driverside and there was no water ... so i opened the pass door. once i opened the door the water started coming down. it was alot. it was prob about 3-4 oz that dripped out.
Old Mar 15, 2006 | 06:55 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
i think i fixed the leak. i took some pliers and crimped the seal all the way. no water so far. i washed my car and then took a spray bottle and tested it. nothing ran in the car. now i must try and fix the sunroof. how do i get to the tube? i cant even see it. all i see is the tube where it hits the firewall and exits the cabin. do i have to take my fender off to get to it or my cowl?
Old Mar 22, 2006 | 07:27 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
well i thought i fixed it. but today i really did. as reno said it was the drain tube. i had a hell of a time getting to the top of it. and then that didnt help. then i had a hell of a time getting to the bottom of it. what a day it has been. when i finnily did get to the bottom, i blew compressed air throught it and dirt and grime went everywhere because i had the tube disconnected from the sunroof.
well thanks for everyones help. another prob. solved. now my next task is replacing the seal on the cowl. i broke it thinking the tube went in there. is it necessary to replace it? it is really messed up.
Old Mar 23, 2006 | 05:06 AM
reno96teg's Avatar
glad to hear.. nice job! :thumbup:
can you get pictures of the seal that you messed up? in fact, create a new thread on it.
hopefully you'll get more experiences on it, than in this thread. :hs:
