View Poll Results: what do you think i should do
fix it myself....it is of course my responsibility
13
92.86%
take it to some creep to be ripped off
7.14%
Voters: 14. You may not vote on this poll
hottie in distress!!
Originally Posted by mr.crx
you do not need a timing light period. yes if uoi wanted you could use one just to be safe. but its not a have to. and plus have the people here probably dont know how to use a timing light.
Let's blindly set the timing after completely removing the distributor and installing a new one. Brilliant. I would never mess with the timing/distributor without a light...it's asking for trouble.
agreed 100%, can u do it without a timming light sure u can, but if u want to be certain of the setting and want the optium timing, u need to use a timming light... but u can do it without totally up to the person me person i wouldn't do it without a timming light
how is not using a timing light not doing it right? i have had no problems with all three distrubutors i have changed. so if i was going a head gasket or something of that nature then i would use a timing light. but something like that is easy enough and if you dont have a light its good enough as long as you careful. obviously if you havent done it before then a light would probably be best cause you wont know what to do and you could end up with timing that is to retarded or to advanced.
There's no difference between removing the distributor when you change a head gasket vs just changing the distributor. I can't believe you think there's a difference. Even if you have done it a million times, you're never going to line it up properly. I guarantee you, the timing would be set differently every time.
u know i say screw it there is no point in trying to change someones mind even if they are wrong, dubcac i am with u a 100 percent man but u know what it ain't even worth it let him/her whoever think whatever they want even if it is wrong
To properly change the distributor on a G2 teg, a timing light must be used. If the distributor is improperly installed, the car may still run but the performance will be affected. Moving the distributor towards the front of the car will retard the timing. Moving it towards the passenger cabin, will advance the timing. If the timing is advanced or retarded too much, the preformance will be affected(even gas mileage). This is the reason a timing light must be used. For those who would like to argue the point that this is not necessary, please refer to the Helms Acura service manual(section 23). If necessary, I will provide pages from the Helms manual.
And if the timing is advanced too much, you can detonate. Detonation is fun!
