Seafoam...
Originally Posted by red94teg
Where all did you add it? I am actually wanting to put some in right now but I'm not sure where I should add it for best results.
I added it through the PCV hose while it was running. Shut her off and let her sit for 5 minutes. Start off again and give her a test run.
Yeah, I went ahead and used the Seafoam this past weekend. I just added it to the gas tank and through the pcv valve vacuum hose like you had said. I'd say it was worth using just to see all of the smoke coming out of my exhaust. It was actually kinda funny. But yeah, after driving the car hard for a few minutes I could definitely tell a difference. Good stuff for only being like 6 bucks!
the mileage isnt really an issue. seafoam can be used at anytime when u feel a need to clean out the system a little bit. it you wanted a routine time to put it in id dare say a yearly run of it through the tank and every couple years do the intake. and more as the car seems to need it obviously
