3rd gear popped out
oh by the way, direct drive is also called final drive. Also i did more research and found that chances are its your motor mounts are bad or simply loose. Or your external shift linkage is bad or out of adjustment. Since i believe almost all FWD cars are cable linkage instead of hydraulic, the cables do strech and make em outta adjstment.
oh see, i was wrong. But that is why i said almost all are cable. I should have said not newer ones are cable. Didnt know integras didnt use cable. Thanks for updating me.
h:
