Sound while braking
Old Feb 11, 2006 | 08:43 AM
Integra Integra's Avatar
Integra Integra
Default Sound while braking
I was able to get it on a jack today and saw the boot above the lower control arm on the passenger side was leaking fluid, I don't see a tear it appears to be coming from the side were the clip is. Its not the boot that meets the wheel (CV) its the once smaller above the lower control arm. Heres a pic:
Were can I get the part and is it to hard to replace?
Old Feb 13, 2006 | 10:12 AM
Integra Integra
bump!
Old Feb 13, 2006 | 10:38 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
you might be better off changing the axle, you can get that at your local parts store and bring the old one in so you can get your core charge back
Old Feb 17, 2006 | 07:57 PM
Integra Integra
Whats the axle called though? Its not the axle that connects to the rim its the one further toward the rear, teh steering one..
Old Feb 17, 2006 | 08:19 PM
ginomobile/teg's Avatar
ginomobile/teg
i believe that is the boot covering the inner tie rod which is connected to the steering rack. You may have a bad seal in the rack leaking out power steering fluid. Check the level of your fluid and see if it is going down at all.
