ECU Help
Old Feb 9, 2006 | 07:02 PM
fliptout's Avatar
fliptout
Default ECU Help
I have an 1990 Integra LS. I bought a head with the following numbers: Pr3-3 And a date stamp that read: 9|9 0|4 0|1 9|0. I have been told that it is a 1999 civic Si head or a Type R head. I need to know what is the next step for the ECU part of the swap. I already have the cams, Springs, Retainers, Valves, and Valve cover. I would like to go with the Hondata s300 but I need to know if I need to get a new ECU or if my existing one could be programmed.
Old Feb 9, 2006 | 07:28 PM
Driverman5777's Avatar
Driverman5777
Ok is it VTEC I dnt kno the numbers? And what color was the stock valve covor?
Old Feb 9, 2006 | 07:29 PM
Driverman5777
If it was red it is that of a type R. Are you doing a LS/Vtec?
Old Feb 9, 2006 | 07:31 PM
fliptout's Avatar
fliptout
Yes I am doing the ls\vtec swap. The Valve cover is a Bright blue color. I tried to scrape the paint off but the original paint was removed.
Old Feb 9, 2006 | 07:39 PM
Driverman5777
What does the intake manifold look like is it higher or closer to the bottom
Old Feb 9, 2006 | 08:32 PM
Driverman5777
I do believe though that is an Integra Type R head and that u are going to need a type r ecu
Old Feb 9, 2006 | 08:56 PM
fliptout's Avatar
fliptout
There is no intake manifold. It is just the head.
Old Feb 9, 2006 | 09:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The head is either Type R or B16, but whatever it is, it is trivial at this point. You will need a new ECU since your current one doesn't have vtec support. A P28 chipped with Hondata will work for your setup.
Old Feb 11, 2006 | 07:14 AM
mountaindewguy's Avatar
mountaindewguy
www.phearable.net
they sell chipped ECUs with basemaps and the works, and they are already tuned to a setup that will be similar to yours. this way when you go to get it tuned, it will be MUCH easier to tune it, and if you decide not to get it tuned (which i strongly suggest you do, but not everyone does) it makes it alot more safe to drive with less worry.
go to that site, and contact them, explain your situation, and they'll tell you EVERYTHING you need to know and get you hooked up with a p28.
