rim offset
Old Feb 6, 2006 | 06:38 PM
gsr converters's Avatar
gsr converters
Default rim offset
What exactlly is it and how much do i need. i just bought a set of rims and now i have to sell them because they rub, m fault, they were 18s but they are sold now so now im looking to buy a new set, i want to lower my car with out them rubbing, any suggestions on which rims to buy.:madr:
Old Feb 6, 2006 | 06:49 PM
Driverman5777's Avatar
Driverman5777
I have 17's with a 42mm offset unlowered and they fit perfectly fine. In my opinion I would go w/ 16's they are better for the performance aspect I wish I would have. If you need any other info do a search this has been covered many times
Old Feb 6, 2006 | 06:54 PM
reno96teg's Avatar
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types. [zero, positive, negative]
more info here:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
i don't know what the offset was on those 18's that you mounted, but the overall size of the wheel had something to do with it, i'm sure. in my opinion, anything larger that 16" on an integra just doesn't look right anyway.
i think stock offset is +45mm, but i'm not certain.
Old Feb 6, 2006 | 10:09 PM
gsr converters
i bought the rims without checking anything out and on impulse, got a large sum of money and i needed rims. so i bought the first set of rims that looked good to me. the 18s didnt look bulky, got complimented the short time that they were on my car, but i am now buying a set of 16s, dont know what brand yet but def 16s, i am looking to lower my car a couple inches so anything with 42 offset should be fine right?
Old Feb 6, 2006 | 10:11 PM
gsr converters
or do i want more offset? thanks
Old Feb 6, 2006 | 10:13 PM
dubcac's Avatar
dubcac
I
+42 will be perfect.
Old Feb 7, 2006 | 01:04 PM
Driverman5777
and the 16's will feel sooooo much better than the 18's alot less body roll.
