99' integra dist rotor
Old Jan 28, 2006 | 05:01 PM
i6h's Avatar
i6h
Default 99' integra dist rotor
Cannot remove the rotor, it's really on there tight. Any tips? A set screw I overlooked? Had a good amount of prying press on it and it wouldn't budge, and I didn't want to break anything forcing it. Need help, thanks.
Old Jan 28, 2006 | 08:19 PM
slowG2's Avatar
slowG2
just put some elbow grease into it slugger..j/k
where is the screw at on the distibutor?..if it is on the bottom, just crank the engine (you should be able to see this from inside or have someone help) till the rotor screw is at the top (closest to the valve cover) that should help you get to the screw a little better.
Old Jan 29, 2006 | 07:35 AM
newgsrdriver's Avatar
newgsrdriver
Just like he says, crank it until the screw is visible. That screw can sometimes be on tight depending on who did the last change, so be careful not to strip it.
Old Jan 29, 2006 | 08:32 AM
slowG2's Avatar
slowG2
i have snapped a rotor bolt before....not fun.
also are you using a socket, or a screwdriver, i would try a socket if you can get it in there, i think it is 10mm
hth
Old Jan 29, 2006 | 05:39 PM
i6h's Avatar
i6h
Thanks for the replies, I won't be getting back to this for a few days, but what am I actually going to find, a reg, phillips, allen, or hex head screw.
Old Jan 29, 2006 | 07:25 PM
slowG2's Avatar
slowG2
its going to be a phillps screw, but i would try to use a socket..10mm i think.
