I need Some Help With my car "Missing"
Old Jan 28, 2006 | 01:57 PM
Got_my_air_on's Avatar
Got_my_air_on
Default I need Some Help With my car "Missing"
Hey when i am driving my car and i get the rpm's to around 4000 it starts to miss... its a b16a motor. I dont know if it might be a fuel filter problem or spark plugs..someone please help me,thanks
oh by the way its in a 1990 acura integra
Old Jan 29, 2006 | 08:26 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Do you have a CEL on? If so, check the flashing light opn the computer and see if it is flashing. If no CEL is on, start w/a basic tune up. When is the last time that 90 has had had that done? Have the wires ever been replaced? Bad wires can make the car sputter pretty bad if they are not functioning correctly.
Old Jan 29, 2006 | 09:31 AM
Got_my_air_on
The wires look pretty new, the motor isnt a 90 its a 94-95 I changed the spark plugs, and im about to change the fuel filter i'll change the plug wires today, and ill let you know if thats the problem. Thanks
-Travis
Old Jan 29, 2006 | 03:26 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i had a similar problem... turns out with a new fuel filter/oil change/spark plugs/wires it was fixed... after i got everything done... i was curious what it probably was... so it turns out the fuel filter was siezing up a little bit... as well as the #4 spark plug wire had a minor crack in it... so in higher compression it would actually come out a little bit and give me a shittier spark if at all
