Steering gear boot replacement question???
Old Jan 27, 2006 | 06:53 AM
DA808TWITCH's Avatar
DA808TWITCH
Default Steering gear boot replacement question???
My power steering fluid has seemed to be leaking for awhile so I checked under my car and found out that my steering gear boot has a huge tear in it. I know that if your CV boot is torn for awhile, you might as well replace the whole axle....so my question is, since it seems that my steering gear boot has been torn for a while, is it necessary to replace my whole steering gear aka rack and pinion, or can I just replace the boot?
Also, I am pretty good mechanically, but how much pain in the ass is it to change this on my own?
Thanks guys
Old Jan 27, 2006 | 07:10 PM
DA808TWITCH
Help!
Old Jan 27, 2006 | 07:43 PM
GS-R69's Avatar
GS-R69
Default The proper fix...
You need to replace the rack assembly. The boot is just to keep dirt off the inner tie rod. There is a seal that you cannot see that keeps the fluid in(which has gone bad). If you replace just the boot it will fill up with power steering fluid because the other seal is bad.
If you replace the rack you should flush out the whole system and install an inline magnetic filter if possible.
Replacing the rack yourself may not be too hard depending on your skills. Check a good manual to see if it makes sense or not. Wheel alignment will be necessary and if the car has an airbag in the steering wheel loop the seatbelt through the steering wheel and latch it to prevent damage to the clock spring(contacts behind steering wheel for the airbag).
Old Jan 29, 2006 | 08:57 PM
DA808TWITCH
Thanks for the info!
Just wondering if anyone could tell me approx how much it should cost from any shop to replace my whole rack and pinion for me?
