putting cams in
Old Jan 24, 2006 | 02:58 PM
hachacker5024's Avatar
hachacker5024
Default putting cams in
in my manual for cams and timing belt it says that the cylinder needs to be at TDC on the compression stroke and that maes that the valves are all closed right well if so then how do i make it so that they are all closed with the cams both facing with the up arrows pointing up because on mine there is slight touching and it is opening the spring just a little but so if anyone knows how to make it so that all the valves are all closed that would be great thanks
Old Jan 24, 2006 | 03:00 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
punctuation please :happysad:
Old Jan 24, 2006 | 04:34 PM
dubcac's Avatar
dubcac
I
Line the white mark on the crank pulley up with the timing mark on the timing cover. And get a manual.
Old Jan 24, 2006 | 04:46 PM
hachacker5024
i have a manual and i did all that good stuff. but isnt there supposed no presassure on the valve at all, and that would be the compression stroke which i dont what it is yet
Old Jan 24, 2006 | 05:31 PM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
when you align the white line on the crank with the line on the timing belt cover, as dubcac explained, a couple of the valves will be at least partially open...I've worked in that area twice now (valve lash and timing belt etc replace), and both times, when cylinder 1 is at TDC, some of the valves are gonna be open.
what manual are you using that is saying this?
Old Jan 24, 2006 | 06:47 PM
hachacker5024
im using the chilton manual
page 3-38 under step 11 in the integra
Old Jan 25, 2006 | 07:08 AM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
well as far as I know, some of the valves are gonna be open...I don't know if at any time while the engine is running all 16 valves are closed...just make sure of the aforementioned stuff and make sure you put the new cam gears on the cams and the cams in the head in in the exact same orientation and you should be good.
Old Jan 27, 2006 | 08:02 PM
Patman015's Avatar
Patman015
Gold Member
not all 16 valves are going to be closed, but when you are timing the engine at TDC, it means that the valves are closed on piston #1. Piston #1 is what piston ignites first. No valves are open during the compression stroke, and if there are, then that's some major engine timing problems and valve overlap problems that need to be fixed, may result in bent valves.:eek3:
Old Jan 28, 2006 | 11:49 AM
95tegRS's Avatar
95tegRS
thats what i was thinking.
