gsr aftermarket cluthes
Old 12-24-2005, 02:44 PM
gsr22
gsr22's Avatar
Default gsr aftermarket cluthes
i have a 97 gsr with light mods aem intake thermal exahuast and my clutch is starting to wear. i want to upgrade can anyone recommend the best brand and type.
Old 12-24-2005, 03:06 PM
dubcac
I
dubcac's Avatar
ACT HDSS is perfect for you...I've had mine for quite a while.
Old 12-24-2005, 04:07 PM
gsr22
gsr22's Avatar
also what does the diffrent stages mean? thnx
Old 12-24-2005, 04:35 PM
1turbodc2
got boost?
1turbodc2's Avatar
agreed, and a lighter flywheel is always a nice add!
Old 12-24-2005, 06:05 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
There is no set definition on stages. The higher up the stage will give you an idea of how stiff the clutch is, what shape the clutch disk is, and what the clutch disk is made out of. Personally, I think rating clutches in stages is retarded. What you should be concerned with is the clamping capacity of the clutch if whether that will work with your setup.
The HDSS is a great clutch and is rated for 243 ft/lbs of torque holding capacity. That will give you plenty of clamping force with a slightly increased pedal effort and the smooth engagement of a full surface street disk.
Old 12-25-2005, 11:57 AM
aboobybobpleez
Certified Rice-Rocket
aboobybobpleez's Avatar
i have the exedy "stage 1" which i pretty much a stock replacement clutch with 9 lb flywheel which is a nice setup IMO
Old 12-25-2005, 06:44 PM
mikey_e69
mikey_e69's Avatar
same here brother!!!
Old 12-25-2005, 09:48 PM
mikesta21
93preludesi
mikesta21's Avatar
good luck picking one out jeremy
Old 12-25-2005, 10:24 PM
Exadar
Be Quiet and Drive
Exadar's Avatar
I recently bought the ACT HDSS and a Fidanza 7.5lb flywheel along with a skunk2 short shifter. as soon as I get it installed i'll let you know what i think
Old 12-26-2005, 07:42 PM
gsr22
gsr22's Avatar
hey thnx for all ur help im still some research but im gonna wait until spring to do it my cars in the garage for now and im still drivin my shit box 89 saab till spring but im looking more towards the hdss thx for the help
exadar toda robah
