is this normal?
Old Dec 22, 2005 | 07:53 AM
Illegal B16's Avatar
Illegal B16
New Zealand
why it there all that oil leaking down, is it from the distributor?
Old Dec 22, 2005 | 07:54 AM
tgansert's Avatar
tgansert
is all good
Originally Posted by schmooooooooo
The dirt inside the ports is normal. It is exhaust, do you expect it to be clean?
and all these years i thought car exhaust was such a good emulsifier...
Old Dec 22, 2005 | 11:01 AM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
The gasket is metal. There is no way it will stick on there in chunks. Just pry it off.
I was thinking intake side but still sand that rust off there.
Old Dec 22, 2005 | 09:19 PM
rugsr's Avatar
rugsr
How do my taillights look
yea thats true, y would there be oil there???????
Old Dec 22, 2005 | 09:43 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
In the first and second picture, it is very apparant that you have a nasty oil leak from your cam seal. I would fix that ASAP.
Old Feb 7, 2006 | 09:28 PM
rugsr's Avatar
rugsr
golden eagle black cam seal has been ordered and is in shipment. IS THIS HARD TO DO. the cover is off already and the cams are showing.
Old Feb 7, 2006 | 10:16 PM
Provocateur
On permanent hiatus
Not even. You just have to remove the cam cover on the exhaust side and then pry the piece off that houses the cam seal. Just make sure you use hondabond around the cam seal (not on the o-rings) and that metal piece.
Old Feb 8, 2006 | 03:29 PM
rugsr's Avatar
rugsr
i was reading that you used gray shit from autozone insted of hondad bond for the cam cover......i can use this here too right?
Old Feb 8, 2006 | 04:23 PM
Provocateur
On permanent hiatus
Yes, it is the same thing.
