Indiglo guage
Old Dec 18, 2005 | 01:11 PM
jragon's Avatar
jragon
Originally Posted by dr_jekal01
ok my guage is not staying in place is all right to use a little tape?
what i did is sprayed the contact side with 3m spray glue and placed the gauge on the stock black gauge. works good has lasted about 2 months and no problems.
Old Dec 18, 2005 | 01:46 PM
jragon's Avatar
jragon
Originally Posted by jjang
i have my indiglo gauges hooked up to my parking lights (positive wires, negative just hooked up to a ground source). theyve lasted me over a year. i had to get extra wiring to hook it up to the parking lights. but they turn on whenever my parking lights are on, just like how it would work if it were stock.
My question is do they dim with your dimmer switch or do they stay bright. It would be nice to turn down the glow on mine for long trips. thanks
Old Dec 18, 2005 | 04:08 PM
dr_jekal01's Avatar
dr_jekal01
ok... its on and wired in to all you guys is comments, but when I turn it on it works then I'll try it again and its off the about 3 trys its on again...help?
Old Dec 19, 2005 | 06:56 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Although ricey...I gues...I happen to like indiglo gauges. I don't have mine anymore, but the color was pretty cool. You can use scotch double sided mounting tape to hold your gauges on. If not secure and pressed to the old gauges your needles will stick.
Old Dec 19, 2005 | 08:33 AM
bnuk's Avatar
bnuk
honestly I don't think they are that ricey. My ebay ones have the exact same layout as stock and I like em. Have last about two years w/ absolutely no problems. They have a seperate dimmer knob that controls the brightness, I just adjusted it to what i wanted and stashed it up in the dash.. But if you were creative you could probably wire it through the stock dimmer. I don't even remeber how I wired them now.
bnuk's Avatar
bnuk
Old Dec 19, 2005 | 05:21 PM
dr_jekal01's Avatar
dr_jekal01
did the double sided tape and it works well but my guage will turn on when the parking kight is on and if I turn it off and back on again it won't light up, it takes me about 3 - 4 times to turn it on I wired it like you all told me too what am I doing wrong, I put the switch on cause of this.
help...
Old Dec 19, 2005 | 09:15 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
What I did was butt the red wire of the gauges to the cruise control button, then I grounded the black to metal. The cruise control button was my kill switch for the gauges. On that note, you could also make a separate kill switch w/a 2 or 3 prong (however many wires you have) kill switch.
Old Dec 30, 2005 | 05:05 AM
PiNkHoNdAgRl's Avatar
PiNkHoNdAgRl
can anyone explain to me how to install glow gauges on a 2000 4dr honda accord, i bought some off ebay and thier instructions are lacking. i've heard it can mess up your needles if your not careful and I dont want to do that obviously. so if anyone could give me a step by step I'd appreciate it.
Old Jan 2, 2006 | 08:10 AM
turbolowmaz's Avatar
turbolowmaz
I just took mine out because for one they fade and then look like shit two the tach light went out and I could not see where the needle was.
Mine where wired directly to the dimmer knob. So you could turn down the brightness abit. Most of the gauges havethat little swicth pad that changes colors and controls how bright they are. Make sure to solder them in and then wrap with electrical tape. No other tape with do, most with dry out and fall off. If that happens and the leads touch you could start an electircal fire in your dash. Fun Fun Fun!!!
