Is my car dying?
Old Dec 16, 2005 | 09:05 PM
LIZZIE's Avatar
LIZZIE
Default Is my car dying?
Mar has been heating up bad, engine coolant has been leaking and the heater went out. I was told that it was the sensor was out therefore I replaced the sensor and it worked cause it was not heating up so I did a tune-up then my radiator water started leaking so it's heating up again and I was told it might be a cracked head and I should work on my valves. does this sound consistent??
95 Teg RS 180K
Old Dec 16, 2005 | 09:24 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
yes sadly. you might want to think about a top end (head) rebuild with a new head gasket. is the fluid leaking from the head ? or is it leaking from hoses or the radiator itself ?
Old Dec 16, 2005 | 09:30 PM
LIZZIE's Avatar
LIZZIE
It doesn't look like its the radiator itself. It looks pretty confusing cause I can' t see a hose near the leak either. I guess my car will need a lot of TLC. How much though and can I take it to any mechanic??
Old Dec 16, 2005 | 09:34 PM
CaliDELSOL93si
hmm....it depends. rebuilding is going to be expensive. you can probably go to a good honest mechanic and they can find a used one for you for probably pretty cheap. with 180K miles, you might want to think about buying a used entire short block. That is probably the best way to go. This way you have less miles on the bottom and the top end.
Old Dec 16, 2005 | 09:41 PM
LIZZIE's Avatar
LIZZIE
Default 95 Teg
So should i just go to a mechanic and tell them it needs a short engine block or should I buy the block and take it somewhere?
Old Dec 16, 2005 | 09:44 PM
Brar's Avatar
Brar
ouch, sounds like the previous own rallied the shit out of it
hmotorsonline.com have good engines. u can get the b18b (current engine u have) for i believe 700
Old Dec 16, 2005 | 11:27 PM
CaliDELSOL93si
definately. go with that. A direct fitment install at a shop should cost more then $200 - $300 and if you can get the engine for $600-$700, then you are only spending $1000 to get a complete engine with low miles with no problems.
With a head rebuild, you are easily going to spend that much, and then you are going to have to look at the downside of still have high miles on the bottom end.
Tell your shop that you would like to replace the entire engine block with a rebuilt block or one with under 70-80K miles and see what they quote you. If they quote you anything under $800, then go for it. Chances are that if you get the block from them, labor will be much cheaper. If they quote you above that, order the block from hmotorsonline.com and have them install it.
hmotorsonline.com has great customer service and are always willing to help.
Good luck.
Old Dec 17, 2005 | 02:24 PM
LIZZIE's Avatar
LIZZIE
While I am getting the engine swapped is there anything that the mechanic can do to boost it up a little?
Thanks for the help
Old Dec 20, 2005 | 08:36 AM
LIZZIE's Avatar
LIZZIE
Default Water Pump
SOMEONE ALSO TOLD ME IT JUST COULD BE THE WATER PUMP?? BUT SINCE MY 95 TEG ALREADY HAS 180k SHOULD I JUST GO WITH THE ENGINE REPLACE??
Old Dec 20, 2005 | 08:52 AM
Patman015's Avatar
Patman015
Gold Member
Honestly man, its hard to say what it is without taking a full look over the WHOLE front of the car. I can say that mechanics at the dealers sometimes try to tell the customer that it needs something that takes a while to do because of the money. If you have a mechanic that you trust, or a place that does really good work that doesnt have a bad name, like a garage somewhere where mechanics do honest work, i would take it there. its great to get a second opinion on things, and I myself wish I could look over it. But you almost NEVER want to go with just one opinion, especially from a dealer.
