94 integra ls starting problems
Old Dec 4, 2005 | 08:41 AM
sfb94integra's Avatar
sfb94integra
Default 94 integra ls starting problems
I was driving on the expressway and while going up an entrance ramp the rmp's started to drop pulled off the road then car would not start back up could this be the alternator or starter? spark plugs? last tune up 2 yrs ago , starter replaced in 2000 alternator original I think .. any advice would be great the problem is in the distributor there is no spark ignition module tested its good , ignition coil tested its good , was told it was the crankshaft position sensor which is in the distributor that is not telling the ignition to spark, anyone heard of that? do you agree?
Old Dec 5, 2005 | 11:52 AM
m735is's Avatar
m735is
Any lights on? Check engine, alt etc??
Could be fuse, relay, fuel pump, distributor.
Old Dec 5, 2005 | 01:47 PM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
That happened to me and I thought it was the alternator because I had just replaced the starter, but I took it to auto zone and had them test it and it was fine. I changed the battery and never had the problem again.
Old Dec 7, 2005 | 12:28 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
could be a fuse, starter, fuel problems, are u getting any power at all, could be a dead battery, i had my alternator blow out recently and i could move but only about 20ft before it would die again, several things it could be...more details would be stupendous
ps: welcome to HAN!!
Old Dec 7, 2005 | 06:46 AM
cuccas ass's Avatar
cuccas ass
it could be anything electircal or it could be the fuel filter getting clogged and not letting enuff fuel in
Old Dec 8, 2005 | 04:02 PM
daschwa's Avatar
daschwa
I'd guess fuel related also. Try turning it over for a while, if you start to smell gas then you can probably rule that out and pay closer attention to the electrical components.
Old Dec 8, 2005 | 07:54 PM
tahafisaka6's Avatar
tahafisaka6
Could be several things. But you only need three things to run, fuel, properly timed fire, and compression. If it died out like it did though, I would guess either fuel or fire. Did you car turn over when you turn the key? If so, then most likely it is not your alternator because pretty much all your alternator does is keep the electricity running to your car and charge your battery, basically meaning if the alternator went Ka-put, then the car would run off of the battery til it died and then your battery would be dead as well. So I am assuming that your tried to start it after it died, and it was turning over, just not starting. The first thing I would check for is spark as that is pretty easy to check, just pull off one of the spark plug wires off of the spark plug, shove a screwdriver in the boot so it is touching the metal inside and then holding the spark plug boot or better yet, positioning it in a manner that the metal of the screwdriver is really close to a ground area of the car without touching, have someone crank it over to see if you see a spark. Other variations would be to remove a spark plug or use a spare spark plug and put that in the spark plug wire and then the part of the spark plug that you thread into the head, you touch that to a grounded area of the car, have someone crank over the car and you should see the spark, or use a tester made to check for the spark, or even a timing light. If you dont get spark, then there are a lot of other steps to go through, if you do, then check for fuel, maybe your fuel pump went out. Let us know where you are at after you did this, and I can give you several more tips what to do next.
Hope this helps, Good Luck!
