engine pics
Old Nov 18, 2005 | 04:37 PM
stemyluv69's Avatar
stemyluv69
Default engine pics
Im buying cams tonite for a 97 gsr and wanted to see a few pictures of a b18c with the valve cover off. Close ups would be nice How long should it take to replace just the cams? Also, do you think its imperative to go from a gsr to itr valvetrain with skunk2 stage 1 cams? Thanks in advance HAN homies
-Don
Old Nov 18, 2005 | 05:05 PM
1995Civic's Avatar
1995Civic
I hate ricers
You dont have to upgrade your valvetrain if you're just going w/ stg 1 cams. However, it could never hurt. IMO, I would go with Crower all the way.
Old Nov 18, 2005 | 05:12 PM
stemyluv69's Avatar
stemyluv69
reason i asked was because my buddy had a b16 with ctr cams, and dropped a valve in vtec It'd be nice not to spend the extra $100 for springs/retainers BUT if its suggested then why not. 100 now is a lot easier than a dropped valve later!
Old Nov 18, 2005 | 05:17 PM
1995Civic's Avatar
1995Civic
I hate ricers
It's always better to be safe than sorry.
Although, that problem could have been caused by the person who installed them improperly, or just simply bad luck.
Old Nov 19, 2005 | 05:58 AM
stemyluv69's Avatar
stemyluv69
Can someone please post a couple pictures of the b18c w/o the valve cover?? I just wanna see what im getting into before i rip it apart. Being prepare is always best
Old Nov 19, 2005 | 10:29 AM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
this and this should give you a decent idea as to what it's gonna look like.
are you gonna know what to do once you take everything apart, and what you're gonna need to take apart?
Old Nov 19, 2005 | 11:07 AM
stemyluv69's Avatar
stemyluv69
yup. ive done a few engines, just not a dohc. I just wanted to take a peek under there so i knew what i was gonna see when i pull the cover. Just preparing myself I think the hardest part is figuring out the adjustable cam gears.
Old Nov 19, 2005 | 04:38 PM
1turbodc2's Avatar
1turbodc2
got boost?
i had skunk2 stage 1 cams in my 01 gsr, u don't need to upgrade your valvetrain if yor not planning to go over your 8k redline..
Old Nov 22, 2005 | 12:17 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would invest in a Helms manual. A few closeups won't help with the actual procedure. You have to make sure the timing is dead on and the belt is tight before you put everything back together.
And if you keep the stock GSR redline, stock GSR springs will be fine.
