Engine bore
Old Nov 16, 2005 | 02:50 PM
hachacker5024's Avatar
hachacker5024
Default Engine bore
okay i have a 91' ls and im about to redo the vaulves but my friend suggusted that i should take it to his mechanic and have them bore it .60mm over and drop in some new weisco pistions and do a whole new head and i got to thinking its not a bad idea im getting horsepower increase and the enging is going to be underwarranty and also it saves me time from having to do it. so i just wanted to know if any one knows what a job like this would cost and if someone could tell me some performance numbers i might expect to see in HP.
Old Nov 16, 2005 | 08:03 PM
dubcac's Avatar
dubcac
I
There's no reason to. You won't really gain much at all, it's not worth the $ in my opinion. Plus, you'd have to buy new rings, bearings, rods, etc...not just the pistons. You might gain a couple hp...but that's about it. Replacing pistons is more about strengthening the bottom end for boost/nitrous/high compression/high rpm.
Old Nov 16, 2005 | 08:43 PM
VPUPPY's Avatar
VPUPPY
werd. only do it if you plan on boosting or something later. and only do it if you really plan on keepin the car.
Old Nov 17, 2005 | 03:49 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
If you do a 60mm bore, you best be going NA...
"they" say the safest diameter to bore to = 45ish...
and at 45 (2liter) is even a minor difference...
i'd only bother to bore if i was going to resleeve as well, and push high ass boost... high enough where the displacement will make a difference.
Old Nov 17, 2005 | 09:20 AM
dubcac's Avatar
dubcac
I
You are way wrong. You're thinking 86mm bore, and 84.5mm bore. He's talking about going 81.6mm bore, which nobody even makes pistons for. They do however make OEM pistons for a .25mm overbore, and anything more than that I'd probably want to resleeve.
Old Nov 17, 2005 | 10:26 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
ah yes, sorry... haha, i had just woken up, and had my numbers mixed up... but yeah, what dubcac said...
sorry for the mix up... forgive me? :kiss: :boink:
Old Nov 17, 2005 | 12:23 PM
hachacker5024
