soft brakes
Old Nov 11, 2005 | 05:52 AM
nnor828's Avatar
nnor828
Default soft brakes
I have a 92 rs m/t with 128000 miles. When ever I come to a hard stop my brakes go soft. I replaced all the pads but still have the same problem.
and its only at a hard stop. Where else should i look to trobleshoot .
Nnor828
Old Nov 11, 2005 | 06:00 AM
teg92's Avatar
teg92
WHAT OK YEAH!
have to checked your fluid? checked for wraped rotors too
Old Nov 11, 2005 | 06:54 AM
LT's Avatar
LT
The deer had to die!
"my brakes go soft"
does this mean the feel of the pedal or the stopping power?
if your fluid levels are good (and no master cylinder leaks), no air in the lines, and the pedal is still getting soft. i'd looking into replacing your brake booster.
Old Nov 11, 2005 | 08:22 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
same thing happened to me, pretty soon your pedal is going to go to the floor when you're stopped. it turned out to be my brake master cylinder, whats happening is there is fluid leaking past the seals on the piston in the MC, therefore causing it to become "soft." replace the MC and see what happens.
Old Nov 12, 2005 | 12:22 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i had the same issue...and later replaced clutch and found out master cylinder was leaking as well...when i replaced it had no problems there on out.... 30 bux and 45 minutes and brakes are A-ok
Old Nov 12, 2005 | 01:04 PM
Schwa's Avatar
Schwa
Schiggity
Check for air in the lines first though!
